Old 07-13-2023, 08:02 PM   #1
Coachwork: Ic ce Navistar international
Chassis: Ce 300 school bus
Engine: 7.6L international ic ce 300 school bus
Ficm replacement
Hi folks, I bought a remanned pre-programmed idm/ficm for my 2006 Navistar inline 6 engine 7.6L it's from Alliance power. My questions are had anyone ever installed a pre-programmed idm and if so did it just work without needing any programming I'm being told it will work that the manufacturer has pre -programmed it and no further programming is needed I just find that hard to believe. Also I would be really happy if someone could explain to me by wire color or wire number which relay is my idm relay under the hood of a 2007 ce 300 dog nose bus is or which one out of the 4 relays I have is the idm I have my own thoughts but I'm getting conflicting info. I think it is the one with the violet # k97 wires going to it by I'm being told other colors by some others. I could and probably will just replace them all but I would like to know which is which.
Sp6saz is offline   Reply With Quote
