Originally Posted by sampatch
Hi, all—
Thanks for your help the other day with my inverter/charger. Everything is functioning now, AC reads as normal on the display and the charger is working.
Does anyone know why it would shift back and forth from “fast charging” to “float charge” every minute or so?
I recently watched the Offgrid Garage guy talk about solar charge controller configuration to ensure the charge/float cycles are spaced out enough to allow top balancing. I know you're talking about an inverter, but perhaps it is configurable, and the values are a bit too close together?
