Originally Posted by Booyah45828
Just out of curiousity, the genny in question is dual fuel right? Is gasoline even required for it, or can it run solely off propane? Will you even have gas in the tank?
I was planning on not installing the gasoline tank.
Just using propane is my thought.
I may put in a disconnect on the gasoline line, that way, I could use gas, if needed.
Just make a simple bracket with wing nuts or something to temporarily install the gas tank when parked for a week or more…
