Old 11-13-2023, 10:22 AM   #1
Chassis: Front engine flat nose
GFCI outlets on outside
I am going to put a 120VAC outlet on each side of my bus. They will be daisy-chained together on the same circuit. Do I need a GFCI outlet for each location or just the first one in the chain (like an interior circuit)?
MadCompSci is offline   Reply With Quote
Old 11-13-2023, 10:51 AM   #2
You can chain them together. You’ll need to make this a water tight installation. Maybe a better solution is to use a GFCI breaker or put the GFCI outlet inside and then go to water tight parts for the outside?
Old 11-13-2023, 11:30 AM   #3
Chassis: Ford E450
Engine: V10 Gas
Mine are individually done but they don't have to be-that's just for convenience if one is blown.
I also have them just inside the doors, so if I need power outside I just snake an extension out the door.
gfci, outdoor wire
