Yes.
Typically the ground bar is connected to the metal panel box and the neutral bar is mounted in a manner that it is isolated from ground.
Yes, what Steve said. Determine if the bars are insulated from or connected to the box or if the bar you connected your grounds to is connected to the terminal you connected your neutrals to. If the existing terminals are insulated from the box add an additional grounding bar to the box. You may be able to move the bar your grounds are connected to and screw it to the box.
Also, the wires entering your box need to be properly terminated with a knock out clamp so the metal edge doesn't rub through the insulation in your wire.
Ted
