06-25-2018, 04:12 PM
Engine: 3800 DT466e, Navistar
Headlights
Does anyone know why there isnt a switch to turn on my headlights? I only have two switches one for clearance and the other is the one on the steering column that I figured was the high beams but it only flashes them. It is a 1999 thomas with a DT466E any info would be appreciated 😁
06-25-2018, 04:17 PM
My lights go on automatically when the key is on. There is also a switch for turning them on and off upper left near the steering wheel. Show a pic of your dash switches.
I watched this video and he doesn't mention a light switch. Do you have a hi/lo switch?
06-25-2018, 04:18 PM
Year: 1994
Engine: DT408 6.7L L6
My 94 Thomas has a pull switch just above and to the right of the ignition.
06-25-2018, 04:27 PM
I have switches for the headlights in both buses, my Bluebird leaves the headlights on any time it's running and the switch only changes the market/tail lights.
06-25-2018, 04:55 PM
The knob beside my ignition only operates the clearance lights and the odd looking switch in the dash is a switch I put in to run power from my DC circuit to the interior lights
06-25-2018, 04:56 PM
And it flipped the picture upside down... great 😂😂
06-25-2018, 04:57 PM
The running lights come on with the ignition I just dont have a switch for headlights or high beams
06-25-2018, 05:01 PM
While there may not be an on/off switch, there has to be a hi/lo switch somewhere there.
Is your hi/lo on the turn signal arm like mine?
06-25-2018, 05:24 PM
I had to eliminate the DRL's on the Nuke Bus. The module was malfunctioning and caused the lights to stay on ALL the time.
06-25-2018, 05:29 PM
Theres a high flash on the turn signal but not a switch for full high beams
06-25-2018, 05:37 PM
HIgh beams may be on the floor. Mine are in both buses.
06-25-2018, 05:41 PM
Does not pulling the signal arm towards the steering wheel click on the high beams and clicking it again turns them down?
That's how mine work on a 99 Int. Genesis.
06-25-2018, 06:30 PM
It clicks but doesn't stay bright
06-25-2018, 06:42 PM
Engine: T444E 7.3L
You got to pull that switch all the way out to the second click for headlights.
06-25-2018, 07:03 PM
Does it push downwards away from the wheel? It may be it and it's broken.
Here is my headlight switch and turn signal arm, how do yours differ?
06-25-2018, 07:40 PM
No button on the floor and no switch on the dash I've been trying to figure it out since last month
06-25-2018, 08:31 PM
Engine: T444E 7.3L
On your first pic you posted. Just to the right of the ignition and parking brake knob. That should be the headlight switch that pull out 2 clicks.
06-25-2018, 08:36 PM
Already tried it's only the clearance lights :\
07-05-2018, 05:55 AM
Rated Cap: 42
It should turn on more than the clearance lights. I had one go bad. I popped it apart and the contacts were covered with a greasy black ooze. I ordered a new switch, but I cleaned up the old one and put it back in as I needed to drive. That was a year ago and it still is working like a new one.
07-05-2018, 05:57 AM
Rated Cap: 42
Inside the switch are quite a few contacts. I think they use separate ones for the clearance, tail and headlights.
