Heating/Cooling 1990 International with a DT360 Diesel Engine
I recently bought a BUS and as winter is close, planning to HEAT/COOL it so i'm looking for ideas. As a note I am planning to make this NEW RV quality.
So my questions are listed below.
1. What type of heat/cool unit is best??
--I am looking at a Penguin II High Capacity Air Conditioner with a Heat Pump - Polar White Retail at $1327.00 Shipped. I will be using my BUS more in the winter months for snowmobiling.
2. Has anyone hooked one of these type of roof units up, and if so how hard was it?
3. Powering the unit for 24/48hr or a controlled time or as temp lowers in BUS. I will only be taking 2-3 day weekend trips due to work and know it wont be running the full time but I am planning for the worse case.
4. Can I run zoned ( separate ) section like cooling in the bathroom, garage section and add additional vents other locations? Also will that effect the space for walls and flooring? Like how wide are the vent tubes required ?
