oil light was on while driving or after it shut off?
if the alternator gave up then it couldve been running on the battery which would then go flat and shut you down. do you have ANY lights in the bus that work? headlights? interior lights etc? if everything is dead, id look to the battery or the battery connections on the battery itself, and also the frame ground (where neg big wire goes) and positive wire.. likely a stud on the starter.. if some lights work but are dim, charge the battery and see if it starts.. if it does then check the alternator to make sure its working correctly.. (a digital meter is really a priceless tool to have when something like this happens.. you can measure voltages and such.. but otherwise we are shotting blind..
