Julieminto, !st off, welcome. There's the most common way to charge batteries and that's solar. You can do wind turbines, but that's something you have to work into the design of the bus. Eventually I will have both on mine. My turbine will be on a pivoting arm. The turbine part being a squirrel cage. When laying horizontal, it will be sitting just above the rear roof line to catch the air rolling across the roof as I drive down the road. Pivoted up vertically when parked, will catch any wind/breeze. Other ways you can charge batteries would be any device that runs off of shore or generator power, converting that power down to what ever your battery size is. Hope this helps. No doubt you'll have plenty of good input from other members here.
