Old 01-28-2020, 11:26 PM   #1
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
Help with an outside electrical plug
Can someone tell me what this is for?
JamieJackson is offline   Reply With Quote
Old 01-28-2020, 11:37 PM   #2
It's the connection for your block heater. It keeps your engine warm so it's easier to start in cold weather.
Old 01-28-2020, 11:59 PM   #3
Chassis: IH
As noted, block heater plug. I'd plug it in for temps under ~32, but only if you plan to start the engine the next day, no need to waste power if you're not going to need to start the engine. Typically takes about 3-4 hours from stone cold to pre-heated engine.
