I just ordered two renogy 170ah lipo batteries. I keep my batteries inside the bus under the bed, but I’m not full time so the batteries could freeze in winter. I have heard people mention heating pads etc but I can’t find anything matching that product.
Any recommendations on where I can order a heating pad with thermo switch to keep the batteries from freezing?
Lithium can not be charged around freezing temps and lower. Discharge is not to good either .
Heating blankets are available but where does the power come from .
If you are on grid then it is easy if the batteries have to supply the energy themselves for the heating then you running a high risk over discharging your batteries and damaging them that way.
Good luck, J
I live in coastal Virginia and the winters are moderate so I’m not too sure worried about draining the batteries too low.. I just need to supplement the heat at night.
