Originally Posted by Kwest364
Solar set up:
6x185W panels ~ 1100 W of panels
Is there a way to measure at charge controller to be able to tell:
1. That ALL my panels are working properly and bringing in proper values?
2. How can I figure out the panel wiring configuration? I can't see underneath the panels at all. How can I tell what panels are in series vs parallel?
Bought a converted bus, I didn't do the work myself.
Why are the panels' undersides not accessible?
Each panel should be individually fused, and all the panels' outputs are typically connected in a combiner box before their total output is fed to the charge controller(s). Is there a combiner box that will show how they're wired together?
One possible way to find out how they're connected is to measure the total voltage into the CC. If the voltage is higher than each panel produces, they're probably wired in series; if the voltage is the same as each panel's, they're probably wired in parallel. I say probably, because if they're wired in series
and parallel it will be difficult to determine exactly how they're interconnected. Panels often produce half a volt per cell: my 60-cell Sharp 255W panels produce about 30V.
