Old 01-31-2023, 09:15 AM   #1
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I did a "test meters" 101 video with a giveaway...
Hi gang,
I don't link to every video that I do...that would be annoying. But this video includes a giveaway of 3 multimeters and I'd like for you all to be eligible. Make any comment at all...the weather, I'm annoying after all, whatever...on the video and that will give you a chance to be randomly picked.
These are cheap meters. They're only $10 each on Amazon. But I was impressed with what they do (and how they do it), so I would certainly recommend them to new bus owners.
If you want to buy one, they're here: https://amzn.to/40jFH3R and you can use the coupon code UD3ZYIYB to get 10% off the already pretty darn cheap price.
https://youtu.be/bvRoHuYrV8Y
Old 01-31-2023, 05:25 PM   #2
Tejon7's Avatar
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
Thanks Ross, that was another good video. I've been missing them lately! Didn't leave a comment because I don't need another meter, but I hope the freebies go to good homes. Awfully nice of you to share knowledge AND tools with the community.
Tejon7 is offline   Reply With Quote
Old 01-31-2023, 08:02 PM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Thanks, my friend! I'm uploading the Load Pro video right now. No giveaway on that...but it's a really valuable addition to my meter and it's helped me find some faults that I would have otherwise missed. It's worth looking into, if you haven't discovered it yet.
Old 02-01-2023, 07:05 AM   #4
even a cheap meter is better than no meter... when I drive my electronic-engine bus the one tool I make sure I always have is the meter.. while ive never had an electronic failure on the road.. the meter would be invaluable..
my last trip I did have low beam headlight failure and before I did anything I tested for voltage at the plug... so much easier than assuming the bulbs went bad ... turns out i had a connector come partially unplugged under the hood.. but the meter showing voltage on one side and not the other lead me right to where I clicked it back together and good to go.. without the meter I would have been sunk or wasting a ton of time..
in most cases the meter doesnt have to be super accurate.. just knowing if you have any voltage or a short or any resistance is good enough to track down a broken wire..
accuracy really only comes into play if you are tracking down a computer issue with random failures where you need to measure resistance of sensors and such...
I carry a good professional meter for that reason but generally speaking most any meter works for 98% of what people are working on in busses.. even the "oops I cut a wire and wont start" issues..
Old 02-01-2023, 07:28 AM   #5
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
in most cases the meter doesn't have to be super accurate.. just knowing if you have any voltage or a short or any resistance is good enough to track down a broken wire..
Agreed, Christopher! I will say that the Load Pro leads have been a great addition to my primary meter. I've used them for about 3 years now and I'm impressed with how well they help me find issues...especially those pesky resistance problems.
https://youtu.be/k34fPKeO0LM
