Originally Posted by Michigan501
Im having this exact problem... What is the "st" terminal on the key switch? is it labeled or do i need to know by looking at it? Also when you say "the button in the back" which button are you referring to, the button you press that starts the bus? I apricate the input
Yes. “I” “B” “ST””AC” should be marked on the switch itself. Ignition, battery, start, and accessories. And yes, wire to the button in the back. With this method you are essentially pushing the back button from the drivers seat.
If you have a 2000 and up Thomas HDX you can bypass the vandalock system buy jumping a start relay in your dash fuse panel.
No need to run a wire front to back!
On other Thomas busses,2000ish and up, you have the same start relay to jump. I just don’t know where it is located.
Dave
