I thought I would start a new thread here in case anyone wants to follow the Genny Install.
In October of 2019 I bought a short yellow school bus with seats off the FB marketplace and literally just went to town on it. It went too slow, so while I was building the inside I bought another schoolbus and swapped the transmissions so it would tool down the motorway.
this thread though is the genny install
We have a 1998 THomas 7 Window Vista
T444E engine and an Allison 2000 transmission
[/url]
and of course the inside for those curious
I picked up this 1996 Onan Emerald Plus 4k for $100 on FB last thursday.
It's missing the muffler, and the remote start panel. However I DO luckily have the wires and plug to the control board to fab up my own remote start panel.
The guy wanted $450, I offered $200 and a week later he said ok. Drove 1 hour to see it, and the starter bendix wouldn't engage. He agreed to take $100 since he couldn't demonstrate it would even move.
I got it home, stripped off and cleaned the carby, pulled the starter and greased it up. She turns over and I verified 120 PSI in both cylinders, so I don't think it has a lot of hours on it. Also cleaned the slip rings and the brushes are still very long, another indicator of lower hours.
She fired right up and made power that evening. However the next morning she wouldn't stay running and was blowing the fuel pump fuse.
Broke it down, did a LOT of maintenance items anyway (slip ring cleaning and other bits) and became very familiar with its internals as I have never seen one before.
In the end it was learned that too many pints in me was the issue and that the night before when I was messing and cleaning after test I had incorrectly wired the relay. So I was the duffer, and all is now well.
Next on was to fabricate a new down tube. Looking online this part is $50, and being a tight bastard I used one of the Bus seat brackets left over (I save most metal) and made my own. The Previous owner had left the bolts, and the gasket... just no muffler. So I had the gasket to make the pattern.
the gasket
The Bus seat scrap thingy
I filled in the hole that was kinda in the way of making the piece and then traced it out and drilled the holes
using regular hand drill, and a vise... my drill press broke and I have not gotten another...
Then cut and shaped it with a harbor freight grinder and a flap wheel
and ended up with this
which I welded a chunk of leftover gas pipe from some other project.
I was telling the missus I can't even remember what the gas pipe was bought for or what I used the rest on.
Then bolted my new flanged down pipe on
Next I built a "Fake Genny" to use when mocking up and deciding where to put the genny, as the real one weighs around 175 lbs.
So far the stern under the rear of the bus where the motorcycle is stored is the best location... Width wise the genny was too low
Lengthwise however it tucks up nice and tidy.
Yes, I said under the Motorcycle
All for now... headed to the coast to see how the summer house fared during hurricane Isiases or whatever it was called
I'll be back onto the project Sunday on return
Cheers
