10-18-2021, 12:45 PM
International 3800 wiring diagram dt466
I usually find stuff using Google but no luck finding a International 3800 school bus wiring diagram for a dt466. Not sure if the dt466 makes a difference as its all mechanical, no Jbus or OBD port
The fuse box is a rats nest so need the manual to try to clean it up and also to get a basic understanding of the electrical system.
Any help would be greatly appreciated.
Thanks!
The Valhalla Bus; currently located in Arizona
-Navseeker
10-18-2021, 03:55 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
also add model year and body type
at this point all we know is international chassis with a 466.
10-18-2021, 07:38 PM
model year 1996, body type D
10-19-2021, 05:01 AM
Year: 1994
Engine: DT408 6.7L L6
If you are looking for body wiring, we would need to know the body manufacturer (Thomas, Bluebird, Amtran, etc...). If you are looking for chassis wiring, there isn't much of that if you have a mechanical DT466.
10-19-2021, 05:20 AM
what year? I have the books for the 1990 model year which is for mechanical engines..
10-19-2021, 06:56 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Like DJ said...there's not much for the chassis, so I will assume you're talking about the body wiring (all that stuff for the sign and flashers and exit sensors). As mentioned, you'll want to tell us who made your bus body.
Where in AZ are you? We're up near Flag and could help out if you get stuck.
Please follow the "cut then check" rule...if you cut or disconnect a wire in there, start the engine and then see if the bus will move (goes into gear and brakes release). Too many new owners remove a bunch of stuff, then find out their bus is now a brick.
10-19-2021, 11:13 AM
Engine: DT466 / MD3060
No wiring diagram, but we have a '95 3800 - might be similar setup to yours
I was able to remove about 70% of the wires myself by tracing them all over the bus. Most of then were speaker wires!
Our dash nest isn't perfect but it is way better than when we bought her - I can actually see what is going on in there and gave made some additions with no problems (backup camera and Hella 4x4 lights)
Tedious, but tracing every wire from switch to end was the best bet for us.
Most wiring diagrams leave me more lost than when I started anyway, but thats just me hahaha
10-19-2021, 11:30 AM
good point, its for a Amtran (Genesis) body.
I did find a pdf copy of the wiring diagram on reddit of all places
10-19-2021, 11:33 AM
its for a Amtran (Genesis) body from 1996
10-19-2021, 11:37 AM
We are in Phoenix heating up Not stuck but greatly appreciate the offer.
I am from Norway so love the cool nature in Flagstaff , it's a great place to be.
10-19-2021, 11:39 AM
Good point about tracing every wire, may be the best way.
I did get a pdf wiring diagram (the manual) of the Amtran Genesis, tell me if you need a copy.
-Terje
09-02-2022, 10:19 AM
Engine: Dt466e
-Terje
Can I please have a copy? Leslie.brewer.me@gmail.com
01-15-2023, 06:39 PM
Chassis: Blue Bird
Engine: Dt466
Wiring diagram
Where did you buy the 1990 model for the mechanical engines. I have a 1990 International blue bird 3800 with an all mechanical DT466. Thanks
01-15-2023, 07:19 PM
it was 7 years ago.. i think the set was a new old stock set i found on ebay..
08-15-2023, 01:03 PM
-Terje
Could you email me a copy as well please? Blackbirdskoolies@gmail.com
