I had the same problem with my cluster, all the gauges would intermittently quit working and got to the point where they quit working altogether. As Cadillackid describes, removed cluster, detached connectors, removed safety cover, removed the screws retaining the circuit boards, flipped over and re-soldered the pins on the back of the connectors. Gauge cluster is back to working, seems to have solved the problem completely. I had never soldered anything before either, but there's plenty of instructional youtube videos out there about every single aspect of the process. The secret seemed to be to heat the pin only, then touch the solder to the pin, not the gun. Once it heats up enough, it pulls the solder into a pool at the base of the pin.
