Old 06-23-2021, 09:04 AM   #1
Inverter Showing ďAC AbnormalĒ
Hi, everyoneó
I have a Sungold 2000 Watt inverter, and I canít get AC power to work. It shows ďAbnormalĒ on the display. Itís the same problem as in this thread. Any ideas? My breaker box is wired the same as the OP on that thread.
I donít have it connected to shore power.
Thanks
File Type: jpg B121BD2B-6B7E-45A6-A3CF-245481E39944.jpg (197.0 KB, 8 views)
File Type: jpg F3364EE4-3AC5-454B-B912-C6F6C9AE650B.jpg (194.9 KB, 7 views)
File Type: jpg 99F70F62-1F8E-432E-AC42-B908EE5A9A7F.jpg (188.0 KB, 7 views)
sampatch is offline   Reply With Quote
Old 06-23-2021, 09:10 AM   #2
Forgot to add the link. https://www.skoolie.net/forums/f49/i...mal-30159.html
Old 06-23-2021, 11:10 AM   #3
Rwnielsen's Avatar
Chassis: TC1000, 40' MPV
Rated Cap: U/K
Do you have a meter? Measure your input voltage both with inverter off and with it on, just to make sure that it's in the operating range. I would then disconnect all load wiring and check output voltage. If it needs a load to operate, find something like a lamp (100w incandescent) to plug in then check output voltage. Be careful, you're dealing with a lot of available power, both AC & DC.
Rwnielsen is online now   Reply With Quote
Old 06-23-2021, 11:20 AM   #4
Rivetboy's Avatar
Originally Posted by sampatch View Post
Hi, everyoneó
Thanks
I agree with Mr Nielson. Put your meter on it! Otherwise, went on line and read the manual and, not suprisingly, it does not address that error message. It has a 1 year warranty so can you return it? Finally, has it ever functioned ? A bad one out of the box seems all to common lately.
Joe
Rivetboy is offline   Reply With Quote
Old 06-23-2021, 11:23 AM   #5
Rivetboy's Avatar
[QUOTE=Rwnielsen Be careful, you're dealing with a lot of available power, both AC & DC.[/QUOTE]
Remove all jewelery !
Old 06-23-2021, 02:04 PM   #6
Thanks, folks. Iíll check all that out this evening. I can return/get the warranty coverage, so if I have to I can do that.
Old 06-23-2021, 09:14 PM   #7
Hey, friends, we got it working. I checked all the connections and the plugged a hair dryer in while powering it up. It was too much, but it seemed to do something because now the lights turn on.
A new problem: the charger wonít charge. I donít have a 30a outlet at my house, so Iím using an adapter. Could that be why?
Old 06-23-2021, 09:20 PM   #8
Rwnielsen's Avatar
Rated Cap: U/K
You'll get it, one thing at a time
Old 06-23-2021, 09:27 PM   #9
Thanks. Any ideas on why the charger wonít cut on? There are a lot fewer variables here. Wired the inlet, plugged it inÖ.and nothing.
Old 06-24-2021, 05:36 PM   #10
Year: 2008
Coachwork: IC
Chassis: IC CE300
Engine: Maxxforce DT
As I wrote back last year : had the exact same issue with same inverter charger. I confirm that it needs to receive shore power before turning the inverter function on and deliver AC output.
Seb
Seb1 is offline   Reply With Quote
Old 06-24-2021, 05:39 PM   #11
I must have missed that thread. I have it working now, but itís bouncing between float and fast charging every minute or so. Any thoughts?
Old 06-24-2021, 05:45 PM   #12
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
What's the battery voltage when this is happening?
kazetsukai is offline   Reply With Quote
Old 06-24-2021, 05:49 PM   #13
Itís around 14, iirc. Iím not with it right now, but I can check later.
Old 06-25-2021, 11:32 AM   #14
kazetsukai's Avatar
Rated Cap: 76
Sounds like your batteries could be full.
Any loads on the system at all? DC or AC.
Old 06-25-2021, 11:58 AM   #15
Yeah, I wondered that. I assumed theyíd ship to me at less than full. Thereís a little load, but only a very little.
I thought it would stay in float if they were full, though, but itís trying to do both, like I said. I wonder if I should disconnect from shore power, use the batteries a while with tools and whatnot this weekend, and see what happens after I know for sure that theyíre drained.
Old 06-25-2021, 12:09 PM   #16
Rwnielsen's Avatar
Rated Cap: U/K
It sounds to me like you're hovering at the threshold between change and maintain. The small load only make it appear worse
Old 06-25-2021, 12:13 PM   #17
All right, great. Iíll use it on some heavy stuff this weekend and see what it does.
Now would be a good time to calibrate my monitor, I assume.
