Although I have no idea how my Yamaha EF3000iSEB inverter generator produces 12 volts, there is a 12v 12A receptacle on the control panel. Since I can never leave anything alone, I redirected that output to keep the group 24 battery I substituted for the original motorcycle battery charged up. The G24 also powers the pusher and puller thermostatically controlled genny cooling fans and for no reason other than expediency the power passenger seat slide.
Quieting a genny is not simple. Even after studying the energy of noise and gaining an understanding of just what dB's are all about building a successful "sound proofing" box took a number of tries. Without getting into a long discussion, I eventually ended up discarding the entire Yamaha genny case, removing the gas tank, muffler, battery and computer to remote locations and placing the motor and head in a slide out drawer lined inside and out with 3/4" dense rubber gym floor mat. The result was a lowering the original dB rating of 53 dB to 45 dB directly adjacent to the drawer. 45 dB is about the noise a refrigerator makes so I'm happy with that.
A quick note on adding a larger (or straight thru) muffler to a single cylinder genny. This lowers back pressure in the exhaust and actually increases the exhaust report as the noise cancelling properties of back pressure are eliminated.
Of course the easiest way to quiet a genny is to walk out into the woods, dig a hole to set it in and walk back with a 100' length of zippy cord.
