Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-27-2021, 02:45 PM   #1
Is it OK for an electrical cabinet to be uninsulated?
I'm not sure yet where I'm going to put my electrical gear (AC/DC transformer, fuses etc.) in the bus and I don't necessarily have a real good spot for it. I have an insulated bulkhead wall 2' behind my driver's seat and I could easily put the electrical stuff on the cab side of the wall, but this means it would be outside of my insulated and heated living space, so it could get very cold in the winter (in summer it shouldn't really get much hotter than the living space since I won't have AC anyway). Is this OK?
musigenesis is online now   Reply With Quote
Old 07-27-2021, 03:53 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Up to a certain point colder is better, you'll never reach that point. I would be more concerned with heat. You may have to put some sort of temp controlled fan to cool the compartment in the summer.
Old 07-27-2021, 05:23 PM   #3
Chassis: Ford E450
Engine: V10 Gas
Mine is all within the bus. Some is mounted on an open wall; other pieces are under the bed. I didn't want any electrical components outside due to condensation risk.
Old 07-27-2021, 07:04 PM   #4
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
No a/c needed. For you cab, I'd use a nema 3 or better. Indoor/outdoor. No blown dust or ice protection. But better for the cab that nema1.
Many house garages are not insulated & a popular location for an electric panel. Mobile home panels are mounted outside, on a pole.
Frederick Douglass: "A man is worked upon by what he works on. He may carve out his circumstances, but his circumstances will carve him out as well. - I didn't know I was a slave until I found out I couldn't do the things I wanted.
