on the fords, it is just a relay that lets the alternator charge the lift battery, but prevents the lift from draining the start battery when the engine is off, so all it is is a switch that cuts off the flow of power from the start/alternator system to the lift battery,... if you are using the standard auto type battery it should not harm it
2010 ford e350 superduty v8 7 passenger bus
