Originally Posted by lawful-nervous
TL;DR: The lights on the back of the bus aren't working, and we don't know how to tackle the awful rats nest that is the bus wiring. Any advice on how to trouble shoot it would be super helpful.
We're having issues with our bus electrical. We removed the flashers on the front of the bus and the three identification lamps on the front and back (working on replacing those. Didn't know we legally needed them). The back flashers we left on to convert into an extra set of break/turn lights.
Since removing those, none of the lights on the back of the bus work. We can't get any kind of voltage or amperage reading on our multimeter. But the front lights are still working just fine.
Neither of us are electricians and we can't figure out what's going wrong. Our best guess is that we screwed up a ground somewhere.
The bus is a 1996 Thomas international. I managed to get ahold of the electrical schematics (contacted Thomas' support line and told them our bus make and model), but the wiring is a terrible rats nets---all the labels are decaying and illegible and instead of a conduit, the harnesses are held together with electrical tape.... Any advice?
If you are gonna do any kind of wiring you should have a tone generator. This is used for locating wires within a bundle.
something like this ->
Amazon link
It is very simple to use and will help you locate your wires.
I uploaded one of the pages from the file you shared, I believe it is page 5.
You will need to zoom in to see the markup much clearer.
So what you have is 3 wiring circuits. You have the main body circuit which I labeled #1) the "jumper Circuit" which I labeled #2) and finally the end of the cable which I labeled #3).
So #1 should be somewhat easy to locate. Follow the wires from the bottom of the steering column. That should eventually lead you the connector that couples #1 with #2.
Once you find it, unplug it and using either your voltmeter of a test light check the voltages to see if there is voltage present when you turn on the signals or brake light.
I forgot to mention, first check your fuses and also the turn signal relay.
If all is good at connector #1-#2 then reconnect and go towards the back of the bus and locate connector #2-#3. Open it here and again check for proper voltages fluctuation when applying turn signals and brakes.
If all is good here then your last step will be to visually and physically check your grounds, lamp holder and the lamps themselves.
You not gonna have a common ground return wire. all grounds should go right to the metal bus body.
The way to use the tone generator is real easy.
Start from the back of the bus, attached the red wire of the generator to the hot (12v) wire of the stop or turn signal wire, turn it on (the generator not the bus) and using the amplifier/speaker begin to follow the wire that is carrying the tone generator signal forward until you get the the main electrical box.
The tone generator is used for wire locating and nothing else.
Once you located the correct wire bundle and individual wires you can inspect and/or test continuity with your ohmmeter.
While all this might sound overwhelming it really is quite straightforward!
