Not familiar with that brand battery, do you have a manual or link to the product description?
Also can you clarify what charger you are using, what specific voltage is set as the max (this may be called absorption)?
Regarding the Shunt there is no such thing as a Victron Connect Shunt, that is the name of their Bluetooth app it would be either the
BMV (shunt with battery meter) or the
Smart Shunt (shunt only)
And if you have a multimeter, next time the problem occurs, measure the voltage across the main battery terminals right after it disconnects.
Am I correct in understanding your situation:
- You have 2 lithium batteries being charged by a ______ Charger.
- You have a Victron Shunt which shows 99% when you lose all power (to/from the battery) (take a multimeter voltage reading at the battery terminals here)
- You "disconnect" the charger (what does this mean? Physically disconnect?)
- Some amount of time passes (how long?) (take a second multimeter reading at this point)
- You "connect" the charger and the system powers back on, the shunt now shows 100%.
My suspicion is that it may be your BMS acting to protect your battery as you may be overcharging it, but its really impossible to say with any confidence without more details, it could be any number of things, this is just speculation.
