Old 12-04-2021, 04:11 AM   #1
Engine: 24 Valve Cummins
Load center/electrical closet ideal location
So I’m getting close to installing my solar system, battery bank, load center, etc. I have a Front engine bus with underbelly storage behind the back wheels.
I’m thinking about putting my battery bank/inverter in the basement, but I do have the space under the bed which would leave the underbelly area for more Accessible storage. Also on the fence about where the ideal location for my 110 load center/fuse box should go.
What are your thoughts on location? Anything you’ve done that you really like or wish you had done differently?
Tcbitt_PNW is offline   Reply With Quote
Old 12-04-2021, 04:28 AM   #2
dzl_'s Avatar
What type of batteries?
LFP likes to be at about the same temperature that humans are comfortable at. ~55-75 is roughly the sweet spot, above 90 is not good, near freezing is not good (for charging, fine for storage/discharge). So if you will be using LFP, inside the passenger compartment may make sense if you ahve the space.
dzl_ is offline   Reply With Quote
Old 12-04-2021, 04:40 AM   #3
They are the 200Ah Lithium Iron Phosphate Battery w/ Bluetooth
battery bank, electrical, floor plan, load center, location
