Originally Posted by Rulebreaker
After spending hours trying to figure it out they started working. My guess is a connection in the compartment on the drivers side, was loose, as I was messing around looking for something loose and they came on. I am installing a set of aftermarket lights in the bumper in case this happens again. The low beams are terrible so the extra lights will be nice.
I wouldn't feel comfortable leaving things as they are. What happens when you're driving down the road and your lights go out? Before you even had the chance to switch on your high beams it could cause an accident. And what if high-beams are inappropriate at the time & you blind oncoming drivers (another way to potentially cause an accident)? And what if the problem, which you admit not knowing what it is, might affect the high-beams too in the future? Maybe a loose harness plug that houses both circuits but right now only the low beams are losing connection?
Seems a lot easier to troubleshoot your problem and get your headlights working properly, reliably, and safely than adding more lights (which may or may not be DOT legal / aimed appropriately).
FYI you're likely not stuck with those headlights. We replaced our sealed beam headlights with Hellas / H4s. Direct drop-in replacement, legal wattage, and a world of improvement.
