Old 06-25-2024, 06:37 AM   #1
main dash cluster fuse
I have a 2001 international bus, the dash panel has blown a fuse, no apparent reason.
where is it located please. ? Bus runs fine, no gauges
ed.mangold@yahoo.com is offline   Reply With Quote
Old 06-25-2024, 06:43 AM   #2
Many International gauges stop working, either intermittently or permanently, because of wire connector issues. Ours has an intermittent problem, works for awhile then craps out for awhile. Its a common problem for IH buses. There's a service that will fix it if you send it in, or if you're handy you can fix the issue yourself. There's a thread or two on here about it somewhere.
