12-27-2021, 11:31 AM
#121
I've had a fire start from factory install under the seat.
Fat passenger, old worn seat, sprungs shorted across the terminals
Horsehair fumes, out in the desert near Uluru.
Fun times!!
12-27-2021, 11:34 AM
#122
Originally Posted by VaFamily1
You need to acknowledge this.
LOL
I'm not going to insist you admit you're fear mongering
willing to just let it be...
12-27-2021, 12:02 PM
#123
Chassis: International RE
Engine: International T444e
Rated Cap: 76
You can not say that it will INDEFINITELY be safe even in EVERY ventilated case, because the evidence suggests that it can happen then too.
This is what people are so prone to nowadays- taking generalizations and turning them into absolutes. Saying something is _generally_ safe is not the same as saying / implying something is _absolutely_ safe. We don't need to make caricature of the original argument to make points against it... the points have already been made.
Went a little too far here, I think. At worst I'd say john's original wording was bad- people jumped on it, many smelling blood in the water, not exactly the purest of motives imo.
Keep in mind that one can be right about something and simultaneously make a fool of themselves in communication of the ideas- you're saying he's devaluing the thread but are you so sure you're not doing the same?
Keep it civil, people.
12-28-2021, 01:46 PM
#124
Coachwork: IC / Amtran
Chassis: CE300
Rated Cap: 23
Either you aren't paying attention or your belief in your experience has blinded you. There are thousands of documented cases, some of which have been mentioned in this thread, where injury has occurred in a ventilated situation. So it is YOU who are "just wrong". Again, THE POINT IS that THE BENEFITS DO NOT OUTWEIGH THE RISKS. You can not say that it will INDEFINITELY be safe even in EVERY ventilated case, because the evidence suggests that it can happen then too. You need to acknowledge this. But by all means feel free to continue devaluing the thread by beating the dead horse of your logic here. Cheers!
I don't want to jump into this fray, but I've got one thing to say and then I'm out...
I'd be inclined to believe that the vast majority, if not every single one, of those 'thousands' of documented cases you mention can be attributed in some way shape or form to ignorance, or neglect.
If you want to run a power station in a moving vehicle, you'd better know what you're doing.
And if you want to keep running it safely, you better keep up on monitoring & maintenance.
The question of whether the benefit outweight the risks can only be answered by the person implementing the system.
Go away. 'Baitin.
Our Build: Mr. Beefy
12-28-2021, 01:48 PM
#125
Sigh...
Originally Posted by john61ct
Obviously if you are happy to treat your FLA batteries as if they are propane tanks, then you should do that.
I am just saying that it is safe to not do so, as long as the space is properly ventilated.
I really hope no one follows your advice.
Originally Posted by Booyah45828
Everything can be dangerous if you're dumb enough to push it beyond it's operating envelope...
Vent the gasses properly, and operate the system properly, and no issues will arise.
YES. Exactly. But not everyone, especially new people to battery technology, can or will understand this. Therefore, the risks should be explained and not dismissed off hand as complete "poppycock and balderdash" (I think those were the terms used - can't remember who it was).
LOL
Hmmmm...IF that were true then why haven't you dropped it by now.
Fun times!!
Thank You for finally acknowledging this. All I was asking for. LOL
Wasn't really trying to do this. But you make a very good point. In this case storing or mounting lead acid batteries in a passenger compartment or living space is not absolutely safe. It can be generally safe if installed correctly but even a correct installation doesn't account for contingencies with the components, and lead acid is riskier in those cases. I understand the risks and choose not to do so. Someone else who does choose to do so ,feeling perfectly confident, should feel free as such but should not encourage others to dismiss potential safety warnings or hazards. THAT was actually my point, and John was doing just that.
...you're saying he's devaluing the thread but are you so sure you're not doing the same?
Ok, I'll admit...not ENTIRELY sure. But, if he had simply responded with something like "I disagree with you", after having tried to explain his position (which I had no trouble grasping in the first place), and moved on I wouldn't have made that assertion. But alas, it's the internet, and there's always an axe to grind. Sigh...
I now declare this horse sufficiently dead
LOL! I highly doubt it. But I will walk away with my beating stick and stop participating.
12-28-2021, 01:50 PM
#126
Couldn't agree more
I think this statement says it all. Couldn't agree more. Thank You
12-28-2021, 04:45 PM
#127
I also agree with that wording.
Of course shorting across battery posts is a completely separate issue from the "dead horse" gassing issue being discussed.
I have also put my stick away on that issue.
12-29-2021, 06:16 PM
#128
Rated Cap: 31,800 pounds
It ain't dead. But Darwin can take care of the final licks.
