Originally Posted by WiredForStereo
Thanks for sharing.
How do you like them?
Looks like you could fit possibly twice as many on there, if they're flexible enough to go further down on the side. If it were me (and I realize it is not) I would put them on say, four parallel strings with independent MPPT controllers to get the max production no matter the orientation.
So, I could use more power...
In terms of more of them... These ones weren't quite flexible to rotate them.. and they're about 1" too long
.... But.. I could use fewer, larger panels and get more overall power.
I have them in parallel connections in 8 rows, 4 with 3 panels per row and 4 with 2 panels per row.. I then series connect the "like" groups and then divide them across two MPPT controllers feeding 4 220AH batteries in parallel.
