Originally Posted by xrw44
I don't have the latch but I found this pic of the wiring before I removed it. The white, yellow (B32) and blue wires are now protruding out of the new wall. I have tried grounding the yellow wire and there was no change.
Per haps we can figure this out? I see too many blk wires!
Blue goes where?
Yellow is nutted to a blk that goes where?
The plunger switch has 2 common white wires and 2 common blk wires. Does the switch have additional connections? When the door is closed, the plunger connects the wht and blk wires?
A body ground is connected to a wht and a blk wire, from the switch ?
Grab a piece of paper and try to draw out the circuit the best you can.
The push switch basically will break the circuit when the door is open and that is why the bus won't start. When the contacts are closed the circuit will function and bus will start.
You picture does not tell me much so your gonna have to slow down and take this step by step, it is quite easy. Got more pics?
Your very first pic, where was that yellow box located and do you have pics of that?
What transmission do you have in the bus? depending on the trans you might be able to "disable" the door lock circuit another way, but don't get excited just yet.
Look at the diagrams that I pointed you to, most bus circuits will be either the same, or very close to the diagram.
Oh yeah, don't disconnect anything els if you don't know what your doing.
Take pics, ask questions first, then and only then, remove or cut wires!
