Originally Posted by kazetsukai
I think the problem with the DALY for balancing is that it does balance only at a very high voltage, when many of us want to charge conservatively- I for one don't want to charge much higher than 3.5V, which I believe is under the start balance voltage.
I think the smart BMS allows you to program balance voltage, I'll see one way or another as I'm going to do a lot of custom integration with mine. Balancers should be relatively idle most of the time for very new battery banks, cool link though.
Can't wait to get the new one and learn how to use it.
I'm hoping between the Renogy Charge Controller and the BMS I can set up a couple of modes of charging:
-Full/Max, for heavy usage;
-Weekender, for medium usage;
-Idle, where the cells sit at half charge pretty much, but occasionally take on charge as they drift down.
The active cell balancer on my battery is operating quite well but my cells are all at 3.5+; I'm going to let them ride down and see whether the device continues to balance all the way down to half charge or so.
