Originally Posted by Whalby
Is there someone who can help me out with my lithium “smart” batteries. They are acting strangely. I am only getting power when I have them plugged into a 12 amp battery charger. Occasionally, when I fiddle with the connections, they will work for a minute or so then conk out.
Have you verified the voltage with a multimeter or some other method (this would be a good first step if not). Measure right at the battery terminals with and without the charger connected.
They are “smart batteries” with “advanced lifepo technology “.
This is just a series of empty marketing words that isn't really saying anything useful. What is the brand or if you don't know that can you link to the product page.
I believe that means they have some safety features that shut them off if there is too much power, they drop too low or reverse polarity, among other things.
Drop-in lithium batteries are different from their lead acid counterparts. They have the battery but they also have what is called the BMS (Battery Management System). Its job is to protect the cells from conditions that would harm them or be dangerous. Normally overvoltage, undervoltage, and often overcurrent, and high and low temperature. They also balance the cells but that is an aside.
Based on the fact that the battery seems to work when the charger is on (how do you know the battery works in this situation?) it seems possible that the BMS is detecting undervoltage and isolating the battery from loads.
Its hard to say with much certainty without knowing the voltage of the battery and the brand/model battery.
