10-03-2016, 12:18 PM
Coachwork: AmTrans
Need help with solar / house power system
Hello all,
I am looking for some help with my solar / battery power system. I recently ordered the Renogy 600w solar kit, and now I want to make sure I get correctly corresponding batteries and inverter setup. I was thinking somewhere in the range of 300-500 AH battery bank and 1,000 - 2,000 watt inverter charger.
One thing that is confusing me in all this is the "battery / Charging Current". I noticed on the 60 Amp Renogy MPPT charge controller it says "Rated Battery Current: 60 Amp". But on batteries such as the VMax Charge Tank it says "Charging Current: 10-35 Amps. Are these two rating relevant to each other?
Nowhere in my many hours of researching have I read anything about pairing charge controllers to batteries. Perhaps I am reading into this too much? Really hoping that my solar selection has not limited my battery options?
Are there similar concerns for sizing up the inverter to battery bank?
Thanks!
10-03-2016, 01:03 PM
Rated Cap: 37,400 lbs GVWR
Originally Posted by WhiteWhale
Hello all,
Thanks!
A 60A MPPT charge controller can provide a maximum of 60A into the batteries, regardless of battery system voltage. If you have a 12V battery system it can provide about 888W (60A x 14.8V); if you have a 24V battery system it can provide twice that wattage at the same 60A maximum current.
A 600W PV system will not usually produce 600W of electrical power - it will typically produce a maximum of about 3/4 of that under most conditions, i.e. you will see about 450W from the panels most days. 450W divided by 14.8V battery charging Absorb voltage (needed for Trojan T-105 batteries in a 12V system) is about 30A, less the CC's own inefficiencies that will drop its output to just under 30A. In other words, your 60A CC is able to be powered from a lot more than 600W of panels. I have two Morningstar TS-MPPT-60 CCs that are each fed by 1020W of panels, and each CC charges four golfcart batteries in series/parallel at about the maximum recommended charge rate 0f 13%. FLA deep-cycle batteries should ideally be charged at between 5 to 13% of their 20-hour Ah rating.
Don't forget to keep all your DC cables short and fat to minimize voltage loss under load. If you need further good advice, it's worth your while to read the Northern Arizona Wind & Sun forum - there's enough expertise and experience there to answer any questions you may ever have.
10-03-2016, 01:47 PM
Coachwork: AmTrans
Thanks John. I appreciate the response. I'm still a little lost when it comes to the charging rate. How does one accommodate the ideal 5-13% ah charging rate? The last thing I want to do is ruin my batteries with the incorrect charging rate. And will this rate change based on the size of the battery bank I use? In a nut shell, I'm trying to figure out what batteries to get for this system.
Thanks!
10-03-2016, 02:39 PM
If for convenience you assume a 10% charge rate, your 30A charge current from the CC would nicely charge a 300Ah battery bank, which is a little more than two golfcart batteries in series and parallel (they would produce about 225Ah at 12V). Four batteries would be towards the low end of the recommended charge rate with 600W of panels. Why not get some more panels? As long as their voltage matches what you already have, they should play well together.
10-03-2016, 04:27 PM
Coachwork: AmTrans
Great, thanks! Theoretically we could go to 800 watts with this kit but not sure we have the rooftop real estate. We will see how things go. Can always expand later. Thanks!
10-03-2016, 05:30 PM
Year: 2005
Engine: Detroit MBE906
I had a 10kw generator picked out to use on my bus, think now I might be better off investing that thousand dollars into my solar bank, that way I don't p!$$ off my neighbors by running a noisy generator, not to mention the savings by not having to buy gasoline/diesel/propane to run it.
10-03-2016, 07:59 PM
Year: 1994
You mean your battery bank you don't run off solar you run off the battery's. Unless you have 4500 watts of solar and tracking system on it plus your in texas or mexico and its just blistering hot out. your always going to want a Gent set. There so versatile out of the box. They have 110 and maybe 220, there governed to run the load required so there very efficient. if you use a propane one like I do there is never any work to be done to them because there is no fuel to plug up a carb . propane can set for 100 years and still be as good as the day you got it. Solar is good for boon docking your running a led light to read abook and your running your full size fridge at 6 amps and you only need a couple deep cycles. plus if it gets cloudy you can start the bus fro an hour and top off the batterys and go back to quite. Home depot sells a propane gen set its green. they sell them on ebay as well. I have had one on my boat for years now. it just works perfect and starts every time. plus if anything ever happens to it i can go return it and get another one any where in the country. Just my thoughts on solar. its just not quite here yet. $1 a watt that you can only get .5 of awatt on a great day for 5 hours? battery storage in lith ion is so expensive tesla can't even afford it. Think small loads and try not to use an inverter if you can. pull right off the 12 volt batterys. Serious solar plans and thousands of dollars changes the whole game.
10-03-2016, 08:28 PM
Year: 2005
Well yeah.... I just lumped it all together and called it solar bank. My water pump will run off 12v, water heater can run 12v/120v/LP, looking at a 3 way fridge as well but that's for down the road... tank heaters go 12v/120v. So the inverter would only be for loads that are 120v only.
This is the genset I had picked out:
Duromax 10,000-Watt Dual Fuel Electric Start Portable Generator
I can probably find a cheaper one elsewhere if I look around but at a minimum I want 10kw with a 50 amp outlet to plug my shore power cable into.
10-03-2016, 09:20 PM
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
I have 480 watts of solar, a 60 amp MPPT controller going to four 6 volt 230 ahr batteries in series/parallel for a 12 volt bank. I modified an upright freezer from HD to make it a more efficient fridge running on 110ac. I have a 2000 watt pure sine inverter and I love it all.
To monitor the batteries I use a victron BMV-702 and it works great. On a sunny day mid-afternoon, i've seen 440 watts of power reaching my batteries. Most partly cloudy days I average about 350 watts for six or seven hours. My panels are "house size" 96 cell panels (2) and I mounted them flat... not screwing around with tilt.
If I wanted to power a 40ft RV and all the accessories you might find on one, I would need that 2k system. But with what I have, I can handle the fridge, computers, cell phones, lights, pumps, coffee pot and cook on an induction cooktop. Mind you, I will be frugal but I think I can get along fine with what I have.
I plan to boondock and if I run low on power or hit a stretch of rainy weather, I'll plug in somewhere or find a campground with power. I personally don't want to use a gen set.
Best of luck!
Ross
10-03-2016, 09:41 PM
Chassis: B3800 Short bus
Alleycat, for what you're doing you could easily get away with solar and propane. Skip the gennie. They're loud and obnoxious.
The three big typical electrical draws for any house are the water heater, electrical range and air conditioning. The only one of those that makes sense to run off of a generator is the AC, which you didn't list as a load.
Running a water heater or range from a generator is a silly affair. You get this great fuel (gasoline or propane) that creates loads of heat, then you waste 90% of the heat to produce a bit of electricity, then you send it across wires that waste more energy (line loss) to produce more heat at the end... Same thing with a water heater. Just burn some propane for gosh sake!
A reasonable solar system would suit you well. I run my small fridge year-round off of 600w of solar panels and a 455Ah battery bank. Both have paid themselves off several times over compared to the cost of a generator and the required fuels. My lights always work, my pumps always work, my fans always work, my stereo always works. I can run a miter saw off of my 2000w inverter. Heck, I even ran a cement mixer off of the inverter! Mind you, it was a beautiful sunny day which helped keep things running along.
Despite what naysayers be sayin', the cost of solar has come down to an incredibly reasonable price. It took 1.5 years for my solar to make sense over a generator. That ain't bad. By no means do I have endless energy, but even living up north there is ample sun to make it worthwhile. I dunno.. it was an easy choice for me.
10-03-2016, 11:05 PM
Year: 2005
That's how I felt too.... I can get by without the generator for the time being since the hot season is pretty much over. I'll be adding A/C to the rig but probably not till next spring, so I will need a generator to run that if I'm not in a campground with shore power. Granted I could probably run it off a battery bank and inverter but I would need a massive bank to do it, and more panels than I would have room for.
I have a freestanding A/C unit but it's only like 5000 BTU which won't be enough to cool the entire coach. It *might* keep the bedroom cool.
I'll have to do some figuring to see if the ~440 ah system will be enough to run the loads I will have, plus an inverter (2500w) I have lying around to run a TV, Blu-Ray player and maybe a satellite receiver when I get it.
The water heater will run off LP, and I can also get a couple of LP heaters though I'll have to keep a window cracked to prevent condensation buildup and also allow fresh air in to keep the CO from building up. Think electric heaters will just be too much of a power draw... 1 might work but 2 would be too much, and from what I've read 2 is the absolute minimum to stay comfortable.
I may also build a homebrew solar powered heater... I've seen videos on how to build it using just wood framing with a plexiglass cover, a 12v fan and aluminum cans painted black.
10-04-2016, 05:36 AM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
to the point, i like that
10-04-2016, 06:56 AM
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Yes! Well written!
I also have a small catalytic propane heater for chilly mornings. Forget electric heat. Even a small electric heater will sap your battery bank.
I have run a Wally World 5000 btu ac during the day, positioned over the sleeping quarters. You're right. It's not enough for the entire bus but drawing a curtain across the sleeping quarters could give you a nice daytime siesta. The ac pulled about 440 watts. But 350 watts was provided by solar! So a 100 watt load on my batteries for a couple of hours was no big deal easily made up by afternoon sunshine.
I could run my ac through the night but it would probably deplete my batteries to maybe 50% charge or thereabouts. You can do that occasionally but it will shorten your battery life. If you can work with 20 - 30% of your battery's total Ah's between solar charges you can get 6 - 8 years out of your battery bank!
I haven't completed my bus conversion yet. Working on it daily. It's a five window short bus with room for only two 96 cell panels comfortably. Maybe three if I hadn't put in the rooftop vent. But my solar has been up and running for three months. I have four 230 Ah batteries for 460 Ah at 12 volts. I'm comfortably running power tools plugged into my bus including a portable air compressor.
Just remember... Even the smallest bit of shading on your panels will significantly reduce their output. Shadow from a rooftop ac or vent or wifi antenna is a no no. Two playing cards placed over a single cell on my panel will essentially shut it off to a trickle. I've watched the charge rate drop as a wispy cloud passed in front of the sun. I noticed only the slightest decrease in light outside the bus while there was a 200 watt drop in charge rate. It is all fascinating to watch and learn.
500 - 600 watts of solar, four deep cell 6 volt golfcart batteries, a programmable MPPT charge controller, 2000 watt inverter (I went with pure sine), BIG (appropriately sized) wire to connect it all, proper placement of panels to eliminate shadowing and a good battery monitor to KNOW what is going on. That's a good place to start (and maybe finish!).
Welcome to quiet, renewable energy!
https://drive.google.com/open?id=0B3...0o3WkFuOWIxUjQ
Ross
10-04-2016, 08:44 AM
I like having my little Honda EU3000i as backup. Inverted power and it is super quiet.
10-04-2016, 08:53 AM
Year: 2005
I wonder if that ~1000 watts of panels would keep six batteries charged up to give me ~660 ah of capacity? I know I may have to utililze a larger charge controller... I saw some that were higher output, also more expensive but not unreasonably so.
This one spits out 96A:
http://www.wholesalesolar.com/390014...rge-controller
10-04-2016, 11:48 AM
I have a 2 hose portable A/C that is soft start and variabe speed.. its 12,000 BTU and pulls about 1100 watts when it is maxxed out... normally on normal load it pulls about 600-900 and when just holding temperature in tempered weather it is at 300-400 or so.. sometimes lower..
if your coach is well insualted and already cool.. say i nthe bedroom that unit would likely run at its lowest speed so you would have a chance at it with solar
10-04-2016, 11:54 AM
Chassis: Blue Bird
Engine: ISC 8.3
Second that. Or an EU7000i instead (it is the quietest in their whole lineup).
If you do eventually come to the conclusion that a generator is wanted that Duromax would probably be unpleasant at best, which is to say outrageously loud. It'd be fine on a construction site or VERY dispersed camping (at the end of 50 to 100 feet of cord) but would be very unwelcome if there are neighbors closer than a few hundred feet.
10-04-2016, 01:25 PM
Year: 2005
Yea I know it will be loud.... I do really like the Honda generators but they're just SO expensive..... if I could find a decent price on a decent sized one then maybe....
10-04-2016, 03:45 PM
Year: 2005
How about this genset? This is actually the first one I found....
Cabela's Outdoorsman 9000W/11250-Watt Remote-Start Generator by Champion
I'm looking on CL for some Honda ones but seems like the asking price is awful high even on the used ones.
10-04-2016, 08:37 PM
Try Ryobi. They sell a decent alternative to the honda for less money.
