Originally Posted by TheDoghouseSkooly
Hello everybody!
We have a 1991 International 3800 (DT360) 21ft long short bus that we are about 90% done with. The electrical system has been up and “running” for a few months. We are finally out on our first week long excursion to get the kinks worked out for longer trips. Our solar system is receiving ample sun (30-50 amps per hour for several hours here in MN). We are also driving a couple hours a day and have an alternator charger for the battery bank. Despite all of the energy input, our Multiplus SOC continues to drop about 2% each 24 hours, all we are running off of it is a Maxair fan and a 12 volt fridge that draws 7 amps at startup and 1 amp to run. It is currently reading 13.2 volts/6% SOC. The Renogy charge controller states we are at 13.5 volts with 100% charge (I’m told this is the least accurate indicator). It seems to me that the solar and smart charger should be more than enough, so what’s the issue? My electrical knowledge was competent enough to set up the below system but still quite limited as far as settings go. Both Multiplus and Rover are using Lithium battery settings. Any assistance would be greatly appreciated. Thank you!
Components include
8- Renogy 100 watt solar panels
Renogy Rover 60 MPPT Charge Controller
Victron MultiPlus 12/3000/120-50 Inverter
Victron Orion TR 12/12/30
2- 200Ah lithium batteries
My Renogy charge controller is always over-reporting voltage by .2 volts. I recommend you get a multimeter and check actual battery voltage at the charge controller and at the battery itself.
I keep my battery at 13.1 when I'm not on the road, then crank up the charge controller to 14.4 when I want to ensure a full charge.
At 13.3 on the Renogy display, your battery could be as low as 13.1, already 'on the shoulder', and although the SOC is not linearly correlated, it could be quite low.
