Old 06-17-2023, 12:12 PM   #1
Sir Octobus's Avatar
No backup lights or alarm
I have a 2002 Bluebird All American RE and I can't get the backup lights or the alarm to work. I have a Doran Monitor from the original setup and the rest of the lights work (turn signals, brakes, running lights, etc.) but not the backup.
There is a positive hot wire that comes into the unit, and I can get the lights to turn on if I jump the positive wire to those going to the lights/alarm, so I know they work. I just cant figure out why it won't click on when I put the bus in reverse.
Any help will be greatly appreciated.
Sir Octobus is offline   Reply With Quote
Old 06-17-2023, 01:00 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i would start with the reverse/backup sensor. most likely on the side of the transmission.
but i dont know your bus either.
Old 06-18-2023, 11:39 AM   #3
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
And if the sensor is on the transmission like mine is, the engine has to be running for it to work as it is a pressure sensor...
johnbloem1974 is offline   Reply With Quote
Old 06-20-2023, 12:03 AM   #4
Duh
It's a fuse in the engine bay. It's even marked "backup lights."
Gosh, how simple.
backup, doran, electrical, wiring
