Hi all, I had the opportunity to drive my bus at dusk the other day, and boy I'm glad I did, because I realized the headlights really stink! The passenger side headlight appears to get to normal intensity when I turn the headlights on, but the focus is off - the beam is really narrow in the vertical axis. The driver's side headlight, on the other hand, only seems to reach "dim" intensity, almost like it's acting like a daytime running light? As far as I've seen, my bus doesn't have DRLs, unless the module is there and doesn't work (I'll check this week to see if I can find a DRL module).
Is there anything else that could cause the driver's side lamp to be so dim?
This pic doesn't do it justice, but you can kind of tell that the driver's side is dimmer than the passenger side.
