Power 12v with bus battery while driving and with solar battery when stopped.
Hey folks! This is probably an easy question, but I keep second guessing myself. I’m running additional 12v outlets and I want them to be powered by the bus battery while driving, then switch to using the solar batteries when the bus is off.
I have an isolator that will allow the solar batteries to be charged by the alternator while the bus is moving, so I thought that could help. I was going to attach the fuse box to the Coach Battery (where the solar batteries are connected) so that they’ll only draw power from the alternator if the bus is running. But if I do that it’ll also be connected to the solar batteries while the bus is running. I don’t know how intuitive it is, whether it would default to the alternator or just use the solar batteries the whole time.
I hope this makes sense.
Looking at the pic, the 2 awg red wire going up is connected to the bus battery. The one going down is connected to the solar battery.
