04-21-2021, 10:39 PM
Coachwork: Thomas Built Freightliner. Allison 2000 tranny
Chassis: Freightliner FS-65 (dognose)
Engine: Mercedes MBE 906 six cylinder diesel
Rated Cap: 35 feet long
Pros and cons of acquiring a portable power station
I hope to buy and start converting a school bus later this summer. For electrical, my current plan is to start with two 12 volt lithium batteries, a charger/inverter and a 3kw true sine wave gas generator. I also hope to charge the batteries with the alternator while driving. Solar may come later.
In addition to 12 volt lights and fans, I’ll be powering some 110 volt devices like a 10 cubic foot fridge, a TV and a CPAP machine. Here’s my question: is there any utility in also acquiring a power station like the Jackery Solar Generator 1500? (I know it’s not a generator.) I was thinking the portability might be handy, and I could move some loads like the fridge to it overnight to keep the main batteries from getting too discharged. But they’re expensive. I’d appreciate your thoughts.
04-21-2021, 11:03 PM
Chassis: TC2000, 40' MPV
Rated Cap: U/K
I think for the same price or less you could add to your existing house batteries.
04-21-2021, 11:28 PM
Engine: 3208 na boat anchor
I put together a 600 amp LFP battery bank feeding a 2800 watt inverter. I came to the conclusion that a store bought battery bank would be a better way to go. When you add up the copper cables, bus bars, and lugs it gets expensive. Let alone trying to pass electrical code, especially at over 24 volt rating.
04-21-2021, 11:58 PM
No the self built option will not only be cheaper but suit your own specific needs better.
To get started use the Duracell / Deka 6V GCs at $1/Ah @12V, cheap as chips treated well will last 7+ years.
If you screw up and murder them, not such a big deal.
Just design the system and select your other infrastructure gear to also be compatible with LFP cells, so if you want to upgrade
7+ times the price but lots of advantages
then that is the only change needed.
04-22-2021, 11:28 AM
Engine: 3208 turbo Cat
Hello John, I know battery solar systems and battery bank depend on the usage, it would help with your experience to put together a basic start up kit to give guys like me to an idea how to start a system.
Thank you for all you ideas and information on this issue.
J
04-22-2021, 02:05 PM
04-22-2021, 07:35 PM
Chassis: chevy
Engine: 3116 catapillar
you should not charge lithium batteries off your alternator you must be real careful to learn about them as thermal runaway is dangerous
04-22-2021, 10:05 PM
what a DCDC is for
Also specialized alt VRs like Wakespeed.
Also a good BMS as backup.
04-22-2021, 10:42 PM
The only advantage I can see is if you have a 2nd vehicle and you want to have a portable setup to xfer over when using that one to take a short trip, etc.
Otherwise, much better to spend money elsewhere.
04-23-2021, 12:41 PM
Even a 12V bank at 1600Ah can be made in modular sub-packs with handles, for transfer from vehicle to boat to trailer to off grid shack.
Depends on strength of course, some people can handle 60lb units, others need 30lb ones.
There is no getting around physics, Ah capacity is linearly correlated to mass
the more "portable" the pack the lower its capacity.
04-28-2021, 03:44 PM
Chassis: 3500
Engine: GMC
Rated Cap: 8 handicapped
Do it all he time. Go through a B2B. I draw 30A out of 135. +20 to run the ship.
