Pulled too many wires pls help
I have a 2003 Ford E450 Bluebird cutaway shorty with a 7.3
l made the same mistake many others have made, I ripped out all the wiring from the cabinet above the driver seat. Including the components that worked with the ignition interlock.
I know how to fix the issue (I think). The problem is I can’t find a proper wiring diagram for the ignition switch. With this diagram I can back trace to full delete the interlock.
Does anyone know where I can find the wire diagrams to trace the ignition and starter wiring? Or if there are other solutions I am open to anything.
Thank you in advance.
