Originally Posted by Danjo
Thanks. The cable lengths are as in your reply.
I haven't connected the panels together because I’m waiting to route to the controller location, but I have six 12 volt, 100 watt panels 2 in series, 3 in parallel, so in a perfect world, 300 watts at 24 volts.
So what is that, 12 Amps Out the controller?
So just to clarify, 6 x 100 Watt panels will always be 600 Watts no matter how they are configured. The amperage and voltage will differ based on arrangement but wattage is always the same.
And if your batteries are 12v, the output of your controller will be 12v, 600W / 12v = 50 Amps
So Assuming 4AWG:
Voltage drop = 50A x (35ft x 0.00024) = 0.42V (3.5% of 12.8V)
Power Loss = (50A x 50A) x (35 x 0.00024) = 21W (3.5% of 600W)
That isn't horrible on its own (not ideal either), but you have to consider how it all adds up. You are losing 21W to heat between the controller and the battery, and then possibly another 21W (maybe more maybe less depending on amperage and wire size) between the battery and the fuseblock, and then another unknown amount between the fuseblock and the appliance.
Also regarding the solar panels, '12v' solar panels are not actually 12v, its a little misleading, your 12v panels are probably between 16-18V, so two in series will be roughly 32-36V. You want to look at the datasheet or the sticker on the back, that'll have accurate numbers for voltage and amperage.
I plugged parameters into the Blue Sea Systems Circuit Wizard and it says 4 AWG is sufficient for the 35 foot RT.
I love the blue sea circuit wizard, its great for standard voltages (12, 24). For your solar panels you'll need to figure out the actual voltage and use a calculator like the one I linked above.
One final thing (that I alluded to above), the calculators can only make recommendations based on the data you give them, 4 AWG may be fine for the 35ft circuit but you need to make sure you are accounting for the total round trip distance that current will travel (all the relevant legs).
I'm struggling to keep this semi-simple but I think I'm failing at that.
West Marine and Blue sea have some good short intro articles on the topic:
Marine DC Wiring Basics
Wire Size and Ampacity
Choosing the correct Wire Size For DC Circuits
Blue Sea also has
this handy reference chart which applies to 12V DC
