Old 03-25-2023, 02:18 PM   #1
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
Relocation dash cluster - International 3800
Has anyone relocated their dash cluster on the 3800 so it's not down so low? I ripped apart the dash on mine this morning to try a few locations. There is enough slack on the connectors (wire and air lines) to move it around, but the main structure under the windshield gets in the way, and I don't want to hack into that.
I ended up putting everything back where it was, but I've never liked having the cluster so low in the dash. Any ideas?
Thanks,
Dave
Dave
Old 03-25-2023, 03:16 PM   #2
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Thanks,
Dave
You can mount a tablet up a little higher with a Bluefire adapter. I've seen some other videos on youtube but they basically ripped out all the metal in the dash and re-built custom to mount where they wanted.
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
Old 03-25-2023, 06:52 PM   #3
ermracing's Avatar
Rated Cap: 29,000
Thanks, I will look into Bluefire, that looks like a cool solution.
Dave
Old 03-26-2023, 06:30 AM   #4
the down load aspect of the 3800 cluster is a royal PITA.. if you look at how freightliner and GMC did it on the bluebirds.. it really looks like they did just that slapped the cluster up high right on the defroster duct..
I went the route of tablet displays(im sure youve seen them a bunch here already).. I mounted the tablets to the bottom sheetmetal of the defrost duct.. they are up high and dont stick up too much into my windshield field of view..
Old 03-26-2023, 08:56 AM   #5
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I've done exactly that on a couple of 3800s, both because of the low positioning and because several of the gauges weren't working. I replaced the speedometer with a GPS unit and installed new gauges from Summit Racing. Here's the panel, cut and bent and painted:
Name:	photo_2023-03-26 06.54.07.jpeg
Old 03-26-2023, 07:42 PM   #6
Chassis: international
Engine: t444e
Rated Cap: short
Ross you might have a market for that gauge panel.
syntaxterror is offline   Reply With Quote
