Old 08-04-2024, 09:06 PM   #1
Question Renogy Inverter Charger Detect AC input bt not charging
I Purchased a Renogy 3000w Inverter charger combo. When plugged into either generator or shore power 30Amp, the inverter recognized the new AC input on display screen; however is not charging the batteries... 4 6V Sealed Lead Acid.
The following are pictures of the set up.
F&KAngeney is offline   Reply With Quote
Old 08-05-2024, 10:39 AM   #2
Chassis: Ford E450
Engine: V10 Gas
Are you running those batteries 12VDC or 24VDC? And does the charger/inverter support 24VDC if that's how you're wired?
Old 08-05-2024, 11:42 AM   #3
I’m running 4 6v batteries in series and parallel to make a 12v system. The best way I could get the most amp hours for the price.
inverter, renogy, shore power
