I dont know of any threads but you will probably discover their is only one wire to each light, your led's will probably have 2, just screw the second light into the metal skin.
I at first just put clear lenses on mine and remove the blinking function, but it would blow the fuse and get the wires really hot, so your idea of LED"s is better, just make sure you dont put too many amps through the wire by getting too high power lights, or just run bigger wires.
my bus thread, https://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
