Originally Posted by TJones
That's alot of weight to put on the roof. I would think it would be much louder and possibly cause the whole roof to resonate. The other problem I could see is not having clearance to put a drain pan under the generator when changing the oil.
Ted
That's where I'm curious - what would the resonant difference be between frame-mount and overhead? Wouldn't the vibration be the same no matter where it is mounted? Engine is rubber-mounted, maybe use some auto engine mounts between the gen mount frame and the bus mount part?
And yeah, probably want a quick-drain hose down to the ground, but that can be run alongside the fuel line going up.
