Attached is the electrical diagram for the electrical system I plan on installing into my 2008 IC International 53 passenger school bus. I am hoping some of you could check this over to make sure I don't burn down the bus accidently or run out of power.
I am hoping to keep this system very simple and avoid any complicated wiring because this bus will only be used for one summer. The DC to DC charger would act as a battery isolator to make sure the main batteries are always charged up before the alternator charges up the aux batteries. I think it would also prevent the aux batteries from draining the main batteries when the bus is off. After the inverter, I would just use a few power strips and extension cords because I am not familiar with 120V wiring. The system would ideally be able to power a fridge constantly, fans at night, and random things during the daytime as shown in the spreadsheet calculations. In order to suit our needs, I am currently looking at:
four 215 Ah golf cart 6V batteries in parallel and series to form a 430 Ah 12V battery
200W solar panel kit to produce power when camping
20A DC to DC charger to produce power when the bus is on and isolate the main batteries from the aux batteries
500W Pure Sine Wave Inverter and extensions cords/power strips
Spreadsheet:
https://docs.google.com/spreadsheets...it?usp=sharing
In the spreadsheet, I made a list of appliances then used simple watt's law calculations to estimate power consumptions. I looked up or estimated real power consumption of each of the things we plan on using and then summed up the power of each appliance for day or night usage. It seems like I would be able to run my preferred day appliances without draining the batteries at all (if the sun is bright and pointing towards the solar panels), since the incoming power would be more than the power consumption. The red appliances aren't being used anymore. The runtimes I calculated assume that there are no sources of power to account for the cloudiest of days or a non running bus. I calculated the usable battery capacity to be roughly half of the deep cycle battery's capacity. The vacant bus power is running a fridge while we are out camping. The far right side of the spreadsheet also shows the links to components.
Is there anything I am overlooking? Are the basic golf cart deep cycle batteries good for skoolie applications? Would the DC to DC charger and Solar Charger be bad to run at the same time to the aux batteries? Would I also ground the Auxiliary batteries to the same chassis as the main batteries? Do I really need a DC to DC charger, or should I use that money to get an additional solar panel?
