Originally Posted by Kentucky Dreaming
Be very careful when unhooking wires. You may turn your bus into a 10 ton brick. Disconnect one circuit at a time and then make sure the bus starts AND moves before proceeding.
It's a DT466NGD also known as PLN with a Manual Trans I can start it with a Screwdriver remove the batteries and and go unless I stall the engine or need lights heat ect.
