Old 02-23-2020, 09:27 PM   #1
Sealant
What sealant should I use to seal the holes for the bolts that are securing the unistrut to the roof of my bus?
Iím planning on using a neoprene-backed washer against the skin of the bus, then a stainless nut, then a washer, then the unistrut, then a stainless washer, then a stainless nylock nut.
Should I be covering the neoprene washer and nut with sealantand then top that with the next washer?
If you have a better idea, please let me know!
Thanks!
Old 02-23-2020, 10:50 PM   #2
sepudo's Avatar
Chassis: fs65
Engine: 7.2 catapillar 3126
Rated Cap: 41 students
Whatever combination of nut washer you choose and then just hit everything with lap sealant. If it's completely covered you're good.
@drivingdharma
sepudo is offline   Reply With Quote
