Old 09-25-2018, 09:22 AM   #21
Engine: 466e
Rated Cap: its Yuge
Yea, i was trying to be gentle
MambaJack is offline   Reply With Quote
Old 09-27-2018, 09:43 AM   #22
Rated Cap: 30k
Originally Posted by MambaJack View Post
Are you planning on running any of that off of batteries or all shore power, that is a heavy load for a battery bank.
We are setting up a 50a shore power setup. But I want to have the option to use some of the a/c options if we are off the grid. I know I won’t be using the air conditioner off the batteries.
FoxFamily is offline   Reply With Quote
Old 09-27-2018, 10:12 AM   #23
Engine: 466e
Rated Cap: its Yuge
Appliances that heat are also taxing on the battery bank. It sounds like you should just run one leg of shore power to a separate box or separate side of you main box and run anything non battery from there. That is what I am looking into.
Old 10-09-2018, 08:27 AM   #24
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I’ve run my rooftop a/c to its own separate box with a 20 amp breaker. It has a separate 20 amp marine inlet out the back of the bus where the generator will be.
Nick
