06-23-2021, 04:46 PM
#21
the answer is do what ever you want.
yes, use 2 cords
the smoke will compensate for the difference.
06-23-2021, 06:27 PM
#22
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
yes, use 2 cords
Ha. That's a good point, Turf.
This is an open forum. Anyone with ideas on the subject should really chime in. It's a great place to help each other build a safe rig.
06-23-2021, 06:49 PM
#23
Traveling
No. It isn't.
The answer is to find the right thing and do that.
And instead of people admitting they have never done what I'm asking and don't know how or if it will work, they post crap like this.
06-23-2021, 06:51 PM
#24
Traveling
People with relevant knowledge and experience should chime in.
Not all ideas and opinions are valid or useful.
06-23-2021, 08:01 PM
#25
Chassis: Ford E450
Engine: V10 Gas
Originally Posted by WiredForStereo
Hang on a minute-I specifically asked you questions about your setup. Are you confusing battery power with house power?
I'm confused! Hard to follow this thread!
06-23-2021, 08:12 PM
#26
Chassis: Ford E450
Engine: V10 Gas
I have a question about using a 240 volt system and shore power.
I've read up on all-in-one solar inverter/chargers, and higher voltage battery banks and 240 volt electrical systems are more efficient, produce higher power, and use smaller wires.
With many of these systems, if you want 240 volts, you just run two of them parallel.
So my question is: What if you're only getting 120 volt shore power, as in most campgrounds and RV hook ups (that I've seen)?
Does it work? Does the system compensate? Does one run two 120 volt shore power plugs?
Okay, I went back to this post, then scrolled down deep to find your link. The system you linked to does NOT provide for shore power, as best as I can tell. It only takes Genset, PV and battery input. Of course, without a spec sheet I'm just reading from the list of features.
The 'Utility Charger' is just a battery charger-no pass-through. You CANNOT connect this system to the grid and use Grid Power.
What a wild ride on this post. Not sure I can do another one like this today!
06-23-2021, 09:15 PM
#27
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
Perhaps, I've not yet confirmed that for myself. I've heard claims made for both.
There’s a sweet spot somewhere between efficiency and cost. If you spend a lot, you can get a very efficient system, that therefore *CAN* work on a 120V system. Lower efficiency, higher capacity systems NEED 240V.
Well duh. You ask for opinions, you get opinions. Some of them may be good, some of them may be garbage. You’re free to think whatever you want about mine. I chose to do 24V, single phase, high frequency inverters, separate components, because reasons.
I didn’t want the all in ones because at that time the options for 24V were limited, the stand-by power consumption was high, and the stability of the firmware of those no-name systems was not established.
PS I googled Growatt manuals, and found this:
Growatt uses the term parallel, even though they are electrically absolutely in series.
Topologically speaking you could make an argument that that are working in tandem, synchronized, and yes, “parallel”… but that makes me cringe.
06-23-2021, 09:25 PM
#28
Engine: 466ci
Rated Cap: 90
Ha. That's why I chose not to try and explain too much. He doesn't even understand the definition of the words in his sentence, but wants a specific answer to a math question that's missing pieces and his formula is not balanced. Like asking a question loaded with lies and expecting a yes or know. (Pun here)
06-23-2021, 09:26 PM
#29
Traveling
They happen to me more often than not. I am a little autistic. I don't think like normal people. So normal people don't know how to answer my questions, because my questions are direct and I have no time to have elementary concepts explained to me by people who don't actually have the answers I'm looking for. And I call it as I see it without sugar coating anything.
Anyway...
I found one I was more familiar with: https://watts247.com/product/2-x-spf-3000tl-lvm-48p/
It ways it will switch to grid power when power fails. "5-in-1 unit. (Not Grid Tied – no feedback, only Grid assist – the load gets switch over to grid when all else fails)"
So I'm wondering, is it a full switch over or does it partially compensate.
Maybe what I'm looking for doesn't exist. That's certainly a possiblity. In which case, back to the default of a standalone battery charger not incorporated into an inverter.
06-23-2021, 09:29 PM
#30
Traveling
The Growatt was what I was thinking of when I asked the original question. However, I couldn't remember the name so I linked a similar product.
I'm wondering if the Growatt pair can accept 120V or only 240V if they're linked.
It seems like they just switch to grid power when all else fails. Whereas I want to charge batteries from grid power whilst also harvesting solar, if necessary.
06-23-2021, 09:41 PM
#31
Engine: 466ci
Rated Cap: 90
Edit:
Oops. Thought I was replying to a pm I received. Dang, pops up.
06-23-2021, 09:54 PM
#32
Engine: C7 Cat
It's been 40 years since a young lady has tracked me down to notify me that "she doesn't want to talk to me anymore". Just happened again. Sorry I hurt your feeling, mam.
Haha! Took you this long?
It’s good to be the king!
06-23-2021, 11:17 PM
#33
hahaha - yea, she called me too.
OP,
some inverters have a transfer switch built, others you have to add your own.
most inverters only have a 30A pass thru for a shore connection if its built in.if the ones you post do not have one built in, then you add it.
if you have 2 inverters each with their own 30a connection, then its simple to wire it as a 50a pass thru, the way you imagine
if you imagine something else, then that is simple too.
06-24-2021, 09:46 AM
#34
Chassis: Ford E450
Engine: V10 Gas
Anyway...
This is helpful information. You might consider making this your tagline instead to scare people off.
06-24-2021, 10:17 AM
#35
Traveling
I thought of that last night, after this episode.
There are two kinds of people, those that understand and compensate, and those that use it as a weapon to beat me with. Naturally, it's something I have often kept hidden, preferring instead to allow people to assume I'm an a-hole.
It's much easier to be an a-hole in this world than it it is to be neuro-atypical.
06-24-2021, 11:36 AM
#36
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Going to avoid some of the back and forth drama, focus on what I see as the OPs actual question...
Many RVs with 50A input (240V split phase) don't actually have any 240V appliances, they just distribute loads over both legs of the 50A service. Therefore, plugging in using 30A service (120V) will work the same- although you still have to keep overall draw within the specs of the service pedestal.
If you want to run 240V appliances however, you will need to provide 240V split phase service from 120V service somehow. Some LF inverters will do that for you, I believe Victron's Autoformer will also do this.
A variant of my inverter takes 120V AC (L1 + N) and will "autoform" L2 from that input giving you 240V split phase output from a 120V source, which will allow you to run your 240V devices off 120V AC. My inverter is wired to take 240V input, and it will autoform N, which has had me scratching my head a bit over how to wire my AC panel (specifically ground/neutral bonding). A happy side effect of this is I'm immune to open neutral failure conditions from the pedestal.
Edit: Attempting to get 240V output from any 120V source should be approached with caution, 50A service exists to provide more power for higher draw devices, you really shouldn't attempt running high draw 240V appliances from any 120V source.
06-24-2021, 09:21 PM
#37
Traveling
Autoform, this is a new term for me.
Is, for instance, the inverter providing one leg of the split phase 240 whilst shore power provides the other, or something like that?
06-24-2021, 09:43 PM
#38
Chassis: Ford E450
Engine: V10 Gas
I've worked with Engineers, so I understand.
06-24-2021, 10:16 PM
#39
Chassis: TC2000, 40' MPV
Rated Cap: U/K
From what I can understand, the unit takes 120 volts and splits it into 2 legs of 120 and rotates one 180 degrees out of phase. He would then have 240 at half the original amperage less operational loss. This is just a semi educated guess
06-25-2021, 08:13 AM
#40
Engine: 466ci
Rated Cap: 90
Having a disability or disorder is neither an excuse nor a privilege. You may very well be arguing with folks who suffer from the exact same condition.
We don't ask for special treatment or whip out our disability as a privilege pass to bend the word. Have a little self responsibility. If you have a weakness, you must build strength. We each have our own burdens to carry.
