Originally Posted by Wildbill1966
No the RV park and campgrounds system doesn’t support 240 volt systems . You will only find 120 volts at these parks . And to be honest most things you will install in your schoolies will be 120 v
You're wrong there bud.
If it's a NEMA 14-50 outlet, which is your standard 50 amp camper plug, you should have 240vac split phase electric at that outlet.
This isn't my picture, but it shows what you have available at each plug, and how it is wired.
If you only have 120v available , the outlet is wired up incorrectly.
