Originally Posted by Lil&Frankie
We have no batteries yet, but the 2 100w panels from GrapeSolar, an Xpower by xantrex inverter 450, and a Grapesolar Comet PWM charge controller so far.
So the good news is that the system is really undeveloped enough that you sortof have a blank canvas and can go whatever direction you want.
The less good news is the components you do have already from the previous owner (with the exception of the panels) aren't that great (PWN controller and Modified Sine Wave inverter), and in my personal opinion, probably are not worth designing your system around. Xantrex is a decent company but modified sine wave is best avoided these days.
Without knowing more details about your system, there isn't much more I can say beyond generalizations
In regards to your question about adding more panels, that will depend on the controller spec's.
But Generally speaking, if you add more panels in parallel (which you would with a PWN controller) you want to make sure that the voltage is as close as possible to the panels you already. This will be listed on the back of each panel. The two figures you want to look for are "Voc" and "Vmp" (or Vmpp). If possible its best to buy identical panels.
Some details on the basics of solar panel wiring can be found
here or
here
